hey guys, wondering if AC shops carry sealants I could use to seal up corners on heat exchangers, I have a slight coolant leak back there, which ice is holding closed for now, any ideas, has anyone had this problem and if so what did you do to fix it
thank you
Discussion Starter #4
thanks f5, that's a damn good idea, some guys at the shop were saying this has been happening to a lot of the sleds here and it's notthing to worry about, perhaps I could just seal it with something...unless it gets worse, I should carry a little bottle of coolent during
thank you
id be very careful with sealants, you dont want to clog any holes that need to flow if ya get my drift. i would just have the dealer replace it under warranty and get it over with . it would not even take a day to repair once the part is in..............
Discussion Starter #6
yes you're absolutly right, he said if it persists, then I should come back on Monday and he'll deal with it then, thanks again
