what is the proper way to bleed a 98 indy 500 fuji 488 motor after a rebuild? also anyone know what i should torque the the head bolts to? as well as the crank case to block torque specs?
Answered the Coolant question in your other thread,
You will need a Adapter to get at the Nuts that hold the Jug ON.
The Torque Wrench Readings need to be compensated for the Length
of the adapter. Motion Pro has one, Winter Haven can get it for you.
