1 - 2 of 2 Posts
My friend has a 1996 XCR 600 the compresion is (Starting on the right if your looking at it from the back) is 125 - 110 - 100 is that ok we are not looking to make if perfect just we dont want it to blow up within the next 2000 miles
the cylinders with 110 n 100 I would bore and replace pistons and rings you probably wont blow it up in the next few 100 or 1000 miles. but it will run like crap, and probably bog bad off the line until revs get up.. Bad MPG's and compression will get worse once the engine gets heat soaked..
<div align="right">index.php?act=findpost&pid=880088
1 - 2 of 2 Posts
