how many inches is it from the post sticking up to the crossbar where the clutch sits ? ...and how many inches around is the top round part ? is the round part 6 inches around ?
I've got one at home I could measure for ya.
I'll post later tonight when I get home after work.
Drew
<div align="right">index.php?act=findpost&pid=880532
5.75" from vertical stem to clutch place center
4.50" outside dia. is the top ring
On the press lever, it's 6" from pivot ctr. to the center of the 4.50' ring
Mostly made from 3/4" sq. tubing
Base legs are 16" in overall length.
Vertical piece is 8" long.
lower center pipe piece is 7/8" dia. pipe and the outer ring from there is 3.75" dia.
Hope this helps and let me know if you need any more help.
Drew
thanks bud , i am working on it , but a friend of mine started it already without the measurements. i might have to change the swing arm thing. i'll get some pics as soon as i can
