1 - 14 of 14 Posts
I see lots of clutch questions lately. this may or may not help .just puttin out there. found it someplace and kept for future reference.
found this. it may be of use.
Super Torquer
• Yellow 160-290
• Gold 190-340
• Black 170-360
Erlandson
Primary (Drive) Springs
Color Part # 2-1/2" Load 1-1/4" Load
Gold PS-13
190 lbs 335 lbs
Maroon PS-14
185 lbs 320 lbs
Pink PS-11
185 lbs 300 lbs
Yellow PS-7
165 lbs 310 lbs
Silver PS-6
165 lbs 300 lbs
Red PS-5
145 lbs 300 lbs
Black PS-4
145 lbs 280 lbs
Green PS-12
145 lbs 260 lbs
Brown PS-3
125 lbs 300 lbs
White PS-2
125 lbs 280 lbs
Orange PS-1
125 lbs 260 lbs
Goodwin Perf.
• 420-505 Purple 140-360
• 420-508 Lime 165-275
• 420-506 Red 170-305
• 420-501 Black 180-330
• 420-509 Blue 140-310
Bikeman Performance
• BMPPS1 140-300
• BMPPS2 150-300
• BMPPS3 160-300
• BMPPS4 170-300
OEM Arctic Cat
• Red 74-228
• Yellow/Green 114-267
• Purple 121-240
• Yellow/White 122-285
• Orange/White 143-290
Dalton Snowmobile Springs
Suggested list price CDN $35.00 Suggested list price US $29.95
Dalton clutch springs are manufactured from high quality chrome silicon wire to exacting tolerances, stress relived and shot peened for long lasting durability.
Polaris/Arctic Primary Springs
Part # Pre Load (lb) @ 2.5" Pre Load (lb) @ 2.375" Pre Load (lb) @ 1.375" Total Force (lb) @ 1.25"
Dalton Black/ Red-white DPPS-B/R/W 147 lb 153 lb 290 lb 310 lb
Dalton Red/ Black DPPS-RB 150 lb 165 lb 300 lb 320 lb
Arctic Cat Drive and Driven Clutch Springs
We keep in stock a wide selection of high quality Drive and Driven Clutch springs from D&D Powersports and Cutler Performance.
D & D Primary: CPC Primary: CPC Secondary: D & D Secondary: D & D Secondary Spring ACT Drive:
Teal - 185/295
Green - 195/295
Black - 190/330
Orange - 170/305
Blue - 170/265
Yellow - 160/290
White - 135/330
Red - 170/330 Purple/White 180/320 Black/White - LIGHT
Blue/White - TO
Red/White - HEAVY Black - LIGHT
Silver - TO
Purple - HEAVY Tan - 110/320
Maroon - 130/340
[ top of page ]
D & D Racing
Springs
200-010
Teal Drive Spring 185/295 $18.00
[ $17.10 ]
200-011
Green Drive Spring 195/295 $18.00
[ $17.10 ]
200-016
Black Drive Spring 190/330 $18.00
[ $17.10 ]
200-017
Orange Drive Spring 170/305 $18.00
[ $17.10 ]
200-018
Blue Drive Spring 170/265 $18.00
[ $17.10 ]
200-019
Yellow Drive Spring 160/290 $18.00
[ $17.10 ]
200-022
Red Primary Spring 170/330 $18.00
[ $17.10 ]
Aaen Primary Racing Clutch Springs
High silicone shot-peened and powder coated clutch springs for tuning Polaris, Arctic Cat and Comet Clutches.
Part no. Description Eng.
Pre-Load Lbs. Full
Shift
Lbs. Rate lbs./in. Price
AAS11054 Orange 120 290 127 $25.00
AAS10034 Purple 150 320 127 $25.00
AAS10038 Yellow 150 380 172 $25.00
AAS10039 Grey 165 280 92 $25.00
AAS10040 Yel / Red 165 310 116 $25.00
AAS10043 White 170 330 128 $25.00
AAS10041 Maroon 185 320 108 $25.00
AAS10042 Gold 190 335 116 $25.00
Arctic Cat ACT Secondary Springs
Erlandson Perf.
Secondary (Driven) Springs
•Fine tune shift rate and full shift out poundage.
•Designed from the highest quality material.
•All EPI springs manufactured using a 5% tolerance.
•ISO 900 Certified.
Sec Springs for 2005-06 Diamond Drive Encapsulated helix
Color Part # 2.2" Load 1.1" Load
Blue ACD2
155 lbs 240 lbs
Maroon ACD3
160 lbs 260 lbs
Green ACD4
200 lbs 285 lbs
OEM Arctic Cat Diamond Drive
Orange 0648-774 175-280
White 110-280
Green 110-290
Goodwin Perf.
• Blue/Orange 185-315
• Blue 215-315
• Blue/White 220-335
• Blue/Red 250-335
• Blue/Yellow 235-335
D & D Racing
Springs
200-025
180/360# DRIVEN GOLD SPRING FOR DIRECT DRIVE $18.00
[ $17.10 ]
200-023
Tan Direct Drive Secondary Spring 110/320 $18.00
[ $17.10 ]
200-024
Maroon Direct Drive Secondary Spring 130/340 $18.00
[ $17.10 ]
Some of the DD springs avail...
SPRING @2.9" @1.6" Rate (lb/in) Comments
DnD mrn 130 340 162 Tested rate
DnD gold 180 360 Adv. rate
DnD tan 110 320 Adv. rate
Chubby blk? 145 390 188 Avail from snowest user chubby, rate unconf.
EPI mrn 120 215 73 Tested rate (adv. rate 160-260)
FBP mrn/pnk 165 265 77 Adv. rate. Looks and feels same as EPI maroon...
AC wht DD 110 280 131 Tests very close to adv. rate
AC grn DD 110 290 138 Adv. rate
Gdwn dk blu 178 269 70 RER spring, Tested rate, good spring with 44/40
Gdwn blu/w 155 285 100 RER spring, Tested rate, another good spring
Gdwn blu/red 200 310 85 RER spring, Adv. rate
Gdwn blu/ylo 220 330 85 RER spring, Adv. rate
AC Ti. 110 260 115 Adv. rate
Team r/pnk 140 260 92 Adv. rate
AC plat. 100 200 77 Adv. rate
AC org. 175 280 81 Adv. rate
Not listed, new goodwin springs, listed on web cataloge without rates, some FBP springs, rated at 2.2"and 1.1" (useless numbers), some EPI springs, same problem, and lots of RER springs that might work, but not sure on. The Team springs require an adapter. Goodwin RER springs work fine in my 2005 without mods.
Fett Brother Racing
Maroon/Pink HSAE201 165-269
Blue/White HSAE202 152-245
Green/White HSAE204 198-288
Low level clutch kit that works crazzy good in the M7 and F7
58/38 helix
200/310 secondary spring Goodwin Dark blue
77 gram weights
140/360 purple primary Goodwin spring too.
F7 set up that seem to work the best.
D&D 54/50 helix and moroon spring 130/340
D&D red primary spring.
Dalton adjustable weights adjust to your sled.
Arctic Cat Secondary
PART NUMBER COLOR RATE @ 1 7/16"
AC-0748-025
Green 157 lbs.
AC-0648-114
Red/White 116 lbs.
AC-0148-227
Yellow 92 lbs.
AC-0648-012
Blue 79 lbs.
AC-0648-010
White 58 lbs.
AC-0148-176
Black 42 lbs.
AC-0648-702
Red/Black ***
AC-0648-732**
Green 260 lbs.
AC-0648-693**
White 260 lbs.
AC-0648-718**
White 260 lbs.
AC-0648-662**
Platinum 160 lbs.
Drive Clutch and Driven Pulley components that are available through the Arctic Cat Service
Parts Department. This information will be useful when doing any fine-tuning on the drive system.
* Titanium
** ACT Driven @1 5/8 in.
***ACT Driven @ 1 5/8 in. (Titanium)
****ACT Driven @ 1 1/3 in. (Titanium)
* Titanium
NOTE: The Arctic Cat drive clutch spring has a
smaller O.D. than the Comet and cannot be interchanged.
* Base is 0.100 thicker than that of p/n 0648-016.
**ACT Driven (10.0 in.)
***ACT Driven (10.4 in.)
SPRINGS - ARCTIC DRIVEN
p/n Color Rate @ 1 7/16 in.
0748-025** Green 157 lb
0648-732** Green 280 lb
0648-693** White 260 lb
0648-718** White 260 lb
0648-674* Red/White 105 lb
0648-662** Platinum 180 lb
0148-227 Yellow 92 lb
0648-012 Blue 79 lb
0648-010 White 58 lb
0148-176 Black 42 lb
0648-702 Red/Black 42 lb
0648-114** Red/White 116 lb
0646-379**** Yellow/White 285 lb
0648-774** Orange 280 lb
0648-776*** Orange 280 lb
ARCTIC CAT DRIVE CLUTCH SPRING CHART
p/n Rate @
2 9/16 in.
Rate @
1 5/16 in. Color
LIGHT 0646-148 53 lb 224 lb Red/Blue
0646-150 72 lb 188 lb Silver
0646-149 74 lb 228 lb Red
0646-376 75 lb 275 lb Gold
0646-147 114 lb 267 lb Yellow/Green
0646-373* 114 lb 267 lb Yellow/Green
0646-155 121 lb 240 lb Purple
0646-229 122 lb 285 lb Yellow/White
0646-248 143 lb 290 lb Orange/White
0646-379 122 lb 285 lb Yellow/White
0646-684 158 lb 290 lb Black
DRIVEN CAMS (Torque Brackets)
p/n Degree p/n Degree
0148-180 45 0648-681 62/50
0148-222 51 0648-682 58/52
0648-001 52/44 0648-683 58/50
0648-002 53 0648-694** 50/36
0648-005 55 0648-696 66/50/0.27 66/52/0.27
0648-006 57 0648-719 68/42/0.34 68/44/0.32
0648-011 48/44 0648-727** 50/38
0648-014 49 0648-729** 48/42
0648-016 57/50 0648-730** 44/40
0648-026 42 0648-731** 46/40
0648-025 47 0648-733** 46/38
0648-024 55/53 0648-764** 44/40
0648-107* 57/50 0648-765** 36
0648-125 51/49 0748-622*** 36
0648-126 53/51 0748-628*** 50/36
0648-448** 36 0748-636*** 44/40
0648-655 70/35 0748-637*** 48/42
0648-656 62/54 0748-648*** 50/38
0648-679 50/36 0748-653*** 42/36
0648-681 62/50 0748-689*** 38
0648-682 58/52 0748-696*** 50/36
Banned
Awesome info! Thank you for taking the time to throw this together.... This should be pinned at the top...
Ya got this same chart, but that D & D teal, according to the D & D site is 170/280.. but the chart and I've heard from others also that it was 185/295. I just had a post today about this with no replys yet. Probably everyone thinks its 185/295 since this chart is going around everywhere but the other D&D springs on the chart match the D&D site.
Moderators, can we get this pinned please? Peace,beeler
1988 Polaris indy classic trail, 1999 ZR 800 CC, 2008 F-1000 ,2016 Pro S 800, 2020 Assault 800
spring rates
:bc:
Super Torquer
• Yellow 160-290
• Gold 190-340
• Black 170-360
Erlandson
Gold PS-13
190 lbs 335 lbs
Maroon PS-14
185 lbs 320 lbs
Pink PS-11
185 lbs 300 lbs
Yellow PS-7
165 lbs 310 lbs
Silver PS-6
165 lbs 300 lbs
Red PS-5
145 lbs 300 lbs
Black PS-4
145 lbs 280 lbs
Green PS-12
145 lbs 260 lbs
Brown PS-3
125 lbs 300 lbs
White PS-2
125 lbs 280 lbs
Orange PS-1
125 lbs 260 lbs
Goodwin Perf.
Bikeman Performance
• BMPPS1 140-300
• BMPPS2 150-300
• BMPPS3 160-300
• BMPPS4 170-300
OEM Arctic Cat
• Red 74-228
• Purple 121-240
Teal - 185/295
Green - 195/295
Black - 190/330
Orange - 170/305
Blue - 170/265
Yellow - 160/290
White - 135/330
Blue/White - TO
Silver - TO
Maroon - 130/340
[ top of page ]
D & D Racing
Springs
200-010
[ $17.10 ]
200-011
[ $17.10 ]
200-016
[ $17.10 ]
200-017
[ $17.10 ]
200-018
[ $17.10 ]
200-019
[ $17.10 ]
200-022
[ $17.10 ]
Pre-Load Lbs. Full
Shift
Erlandson Perf.
•ISO 900 Certified.
Blue ACD2
155 lbs 240 lbs
Maroon ACD3
160 lbs 260 lbs
Green ACD4
200 lbs 285 lbs
White 110-280
Green 110-290
Goodwin Perf.
• Blue 215-315
• Blue/Red 250-335
D & D Racing
Springs
200-025
[ $17.10 ]
200-023
[ $17.10 ]
200-024
[ $17.10 ]
Fett Brother Racing
58/38 helix
77 gram weights
AC-0748-025
Green 157 lbs.
AC-0648-114
Red/White 116 lbs.
AC-0148-227
Yellow 92 lbs.
AC-0648-012
Blue 79 lbs.
AC-0648-010
White 58 lbs.
AC-0148-176
Black 42 lbs.
AC-0648-702
Red/Black ***
AC-0648-732**
Green 260 lbs.
AC-0648-693**
White 260 lbs.
AC-0648-718**
White 260 lbs.
AC-0648-662**
Platinum 160 lbs.
* Titanium
* Titanium
0648-012 Blue 79 lb
p/n Rate @
2 9/16 in.
Rate @
1 5/16 in. Color
I Just ran across this and figured I would bump it back to the top for everyone. Lots of good info here!!
if anyone wants THE setup for a ZRT 600 i will post it here. This was run on a 96 with roundslides, stock pipes, carbs, heads, everything bone stock.
Gut the air box.
310 main jets + or - one size depending on elevation and temperature.
raise the clips (dropping the needle) one spot, so they are now in the 4th posistion from the bottom, 2nd from the top.
50 gram weights in the primary
stock yellow primary spring
cut yellow secondary spring is what i ran, although a red white secondary works very well too.
24/39 gearing
62/50 helix
010 belt
192 studs, I always ran br9eya plugs, some run ES, i diddnt notice any difference, always run shell 91.
This exact setup on an otherwise bone stock 96 zrt600 would pull away from ANY other stock 600 on the lake. believe it or not i pulled a piped f3, zr700, zl800, the only sled who gave me a run for my money was an 04f6 with a Y pipe and a clutch kit with lots of studs, he would sneak out by half a sled and it took me 1000+ feet to reel him in. but i always did.
Excellent trail setup aswell, very sharp throttle response. Hope this helps!
Just make sure you look at the rates?????
Don't just look at the numbers, the compression distance to get the numbers varies from each source.
For example
arctic cat is measured at a distance of 2 9/16"and 1 5/16"
D&d is measured at 2.9" and 1.6" etc.
So if you are just number shopping,
You are not getting the same thing.
They are compressed at different lengths for the rates they advertise
Primary clutch (Drive Clutch) = Front clutch off the motor
Secondary Clutch (Driven Clutch) = Rear clutch connected to drivetrain
Peak RPM = The RPM the machine sits and holds most of the time at WOT. This needs to be in your model's peak powerband for best results.
More Primary Clutch Weight = Less peak RPM & greater belt squeezing force
Less Primary Clutch Weight = More Peak RPM & less belt squeezing force
Primary Spring Starting Rate = Controls Engagement
Stiffer Primary Spring Starting Rate = Higher engagement RPM
Softer Primary Spring Stating Rate = Lower engagement RPM
Primary Spring Ending Rate = Controls Up Shift, Back Shift & Peak RPM
Stiffer Primary Spring Ending Rate = Slower Upshift, Quicker Backshift, More Peak RPM
Softer Primary Spring Ending Rate = Faster Upshift, Slower Backshift, Less Peak RPM
Steeper Helix Angle = Faster Upshift, Slower Backshift
Shallower Helix Angle = Slower Upshift, Faster Backshift
Stiffer Secondary Spring Finish Rate = Slower Upshift, Faster Backshift
Softer Secondary Spring Finish Rate = Faster Upshift, Slower Backshift
Adding horsepower normally means you need to add clutch weight, go steeper on the helix angle, or both. Most small modifications only require adding clutch weight while larger horsepower modifications will require you to change both. Not changing clutching when you add horsepower will result in over-revving.
On some 2-stroke snowmobiles you must add clutch weight or RPM will be too low. 2-stroke pipes are made to work when they are hot. If you do not load the motor hard enough, not enough heat will be built up in the pipe which will result in poor running condition and lower than normal peak RPM. This is about the only case when low RPM is seen that weight should be added.
I will add that I bought a spring tester from Summit Racing. Made a carriage for myself. I tested Black Magic-old ones-, Arctic cat, D&D, and Speedwerx H5 springs and you would be surprised at how low some are. Those are the only 4 I have got tested as of now. D&D's were terrible. The orange 170/305 measured out at 97/250. A few others of D&D's were as bad or worse. Surprisingly the Cat springs were pretty good and didn't loose as much, but still lost. I got some new Speedwerx H5's and they seem to be what they claim. Will do more when I get the chance. For all you guys clutching, it helps to know what you have (IF) your are serious, instead of guessing. I tested a brand new never ran D&D and it wasn't even in the ball park of what it was advertised at on either end!! Makes me wonder what other brands are like!
Great info... Same thing with weights sometimes a 56 will be a 56 and a 58 will be a 56.9 grams and then you wonder why when you put the 58 gram weights in it the rpms didn't come down at all....:fistpump2:
1 - 14 of 14 Posts
