1 - 9 of 9 Posts
i have a few questions i just put in a clutch kit. i drove it back and forth in the yard and it worked good. that was a few weeks ago. today i was moving the sled in the shed and the sled just stopped moving. i lifted the hood and looked at the belt ,it was loose and now when i try to move the sled the belt starts smoking and the sled goes nowhere. how do you tighten up the belt? why is it smoking ? and why is it loose? everything is tight in the clutch. does the belt come off by just pulling on the belt and forcing it off because that is how i was told to take it off and thats how i got it off when i did the clutch.
Did you do the kit yourself. It sounds like there is something else wrong. Can you move the track without the sled running???
Banned
look under tunnel in front of skid, possible you may have picked up a rock and it jammed in between track and drivers??
ya i did the clutch myself. i did everything just like the cd service manual said. i cant check my cd manual now because the cd is not working. with the sled not running i cant turn the track but it will turn if i turn the clutch hub. but with the sled up i can not turn the track by hand.
Banned
<div align="right">index.php?act=findpost&pid=932233
with weight off(track up) you can turn secondary by hand??, but with all other ways it won't turn/move at all?? this points to bindage in track/driver sprocket area pretty much
Discussion Starter · #8 ·
<div align="right">index.php?act=findpost&pid=932268
i also installed a reverse kit. i will take the chaincase cover off and have a look
Banned
<div align="right">index.php?act=findpost&pid=932275
:div20: now that may be a whole 'nother ball game :cn:
1 - 9 of 9 Posts
