Ok thanks, as of right now I just have the pps shock on ,and heard the clicker would work better, was not sure if this was the right one.Yes this will work great on your sled no need to revalve . If to stiff just turn clicker you have 8 different adjustment settings. the 7042196 is the trail version. the 7041906 is the race version i have . usely set on 3 or 4 setting . its nice to be able to adjust for different trail conditions.[/b]
Ya I hear u ,I had it revalved stiffer, and know that will help, as with gear on I weigh about the same,and ride pretty hard at times , but was still thinking about the clicker that it would be better yet.I did the trail version on my 2001 xc 800 , it was the best thing I did to the skid frame ! If you find that you bottom out often and slow down because of this you need one ! Once I put the clicker in I found the front track shock to be to soft but its not real bad. The pps shock is valved for some one that 150~160 lbs and doesnt ride hard or fast , that not me 240lbs with gear and ride like a 20 year old that has no fear.[/b]
