first of all id like to get all the ohm values for it.
also do i need to take it out of the sled to test it ?
just from hearing the way it runs im thinking the high speed coil is bad cus it only run to 7000rpm
and runs like shit getin up there, it also runs better cold
thanks
What I was told:
Low Speed / Black to green 46 ohms
High speed / Brown to green 450 ohms
Ignition Timing sensor Green/white to brown 190 ohms
Injector coil blue/white to blue 21 ohms
Coil Spark plug wire 5040-7560 ohms
Fuel pump orange to orange 1.8 ohms
Lighting coil yellow to yellow .09 ohms
thanks for the info but i found the specs i needed ,
the ones you gave me are for a efi .
heres the specs i found
Ignition coil
Primary .078-.106 ohms +orange -black/white
Secondary 3845-4715 ohms +high tension wire -high tension wire
Charge coil 1134-1386 ohms +green -black/white
Trigger coil 14.31-17.49 ohms +white/red -black/white
Lighting coil .099-.121 ohms +yellow -yellow
spark plug cap 4000-6000 ohms
