Just went out and putz around the yard and when I would hit the gas the check engine light kept on blinking. If I was just idleing the light woudnt come on. what could this be???
Just went out and putz around the yard and when I would hit the gas the check engine light kept on blinking. If I was just idleing the light woudnt come on. what could this be???[/b]
count how many times it blinks and look in your owners manual it will tell you what it means
Your water temp is above 80°C. Probably just an air pocket.
Bleed the cooling system by having the sled in a QUITE upward position (like a steep pile of snow) and run it for a while, fill her up with more coolant, turn her side to side and keep on filling.
