I am installing a D&D clutch kit on my f1000 and would like to know if anyone has a better idea than just grinding down a socket to get the nuts off the bolts? I ground down an old socket and it is still a very tight fit. I see that a few people on here have put clutch kits on and would like to know how you did it.
thanks for any help in advace
If you use a 1/4 inch drive socket its a little smaller diameter than the bigger drive ones. I also grinded a 3/8 drive 11 mm socket down to fit too. I noticed the crosssfire 1000 primary had less room around the pin than the f1000 did.
2018 Thundercat
You may want to try and use the smaller size socket that goes to the 1/4" ratchet if you have one. Those sockets tend to be thinner than your standard 3/8 set, worked for me. Also, the factory had put so much loctite on my weight pin and the set pin in the weight I had to pound the long pin out with a punch and hammer and heat up the small set pins with a torch to loosen them.
