going to change the chain case lube tonight. will any automotive transmission lube work? don't have an arctic cat dealer around need something i can get at the auto store. thanks
Get Mobil gear oil. Comes in a gray bottle w/a nipple end. I can't remember if it's 75 or 85 wt. I used this last season in 2 Yamaha's w/no problems. Switched to Klotz chain case lube this season.
I dextron mercon 3 in mine $1.29 Qt has always worked well. I have used 85w gearoil before and I think its to thick on a cold day it pours like molassis so it puts alot more load on the motor. I would use the trans oil if I were you but its you choice.
mobil 1 syn. motor oil.
