I need some help with the carb setup on my D&D ZRT 1000. This is installed in my 98 with stock VM 38 carbs. The instructions have this as the specs:
95-98 ZRT
Main Jet 500 @ 0
490 @ 10
480 @ 20-30
Needle Jet Q5; (480 series)
Needles in fourth clip
Pilot Jets 40
My sled idles fine at this but is very boggy up to 6000 RPM. Between 6-7000 RPM it seems OK but again gets boggy 0ver 7000 and tops out at 7200 RPM. My mileage is also terrible. I went out yesterday and I was lucky to get 60 miles to a tank of fuel. If I move the needle up 2 clips to the 2nd clip it wakes it up and I am able to hit 8000 rpm but I did a few wide open passes and the plugs are a bit lean. I moved the clip to the 3rd clip and it still seems rich at low end but lean in the middle. I have attached a pic of the 3 plugs after cruising around at midrange. The plugs have about 60-70 miles on them.
I've currently running 540 mains and also have a tempaflow. I went with 540s because I figured that would be the -29C jet for the tempaflow. The 500 is for -17C. I am at about 800 foot elevation.
Any suggestions are appreciated.
95-98 ZRT
Main Jet 500 @ 0
490 @ 10
480 @ 20-30
Pilot Jets 40
