How do you remove the carb rack from a 99 XC500?? Got air box out and there is enough fuel line slack. There is an oil line from the pump to carb, can this be diconnected and reconnected or does it need to be bled before connecting?? I just want to change the main jets, any tips?? Thanks.
if you disconect the oil line you will have to bleed it.
can't you just remove the carbs from the airbox and the boots and monover them some you can change the jets. :beer:
Once you remove the air box, and pull the carbs out of the boots. You can get the main jets out without taking any lines off the carbs. If your carbs need to be cleaned this would be a good time to do it, but then you would need to remove the lines. :div20:
