1 - 18 of 18 Posts
I have always wondered if a 600 to 800 swap can be done easily? Are the crank cases the same? I know they have the same stroke but what else is different? How about pipes are they different?
Is the 1000 bottom end the same as a the other two?
No....the 1000 was a Suzuki motor
The Ctecs are Cat motors.
Suzuki is Suzuki. Not ctec anything. And per Krom, here’s a 600 ctec gasket over a 800 gasket, to verify as posted earlier that the case tops are not the same (bolt holes on left side)
Automotive lighting Font Personal protective equipment Art Auto part
Thought the Suzuki was considered ctec1 and not ctec2.
Ctech 1 is the original 600 cat built. They have change the ctech a few times over the last 8 years.
"Ctec" was the term Cat started using when they started claiming "Clean Technology" for their motors.... Ctec2 is the 2 strokes .... starting with the 600s in 2014 and then the 800s in 2018. Ctec4 is the 4 strokes and I believe Cat has used the Ctec4 on all the different 4 strokes since the term started being used.
Yep. I don’t remember the suzuki ho ever having a ctech label on it though
Because it never did. In 2014-2017 when Cat was still using the Zuke 8HO, only the Cat 600 had the Ctec2 notation. The 4 strokes of those years had the Ctec4 on them. When Cat released their 800 for 2018 model year, it got the Ctec2 notation.
1 - 18 of 18 Posts
