Bleeding oil pump
12K views 17 replies 6 participants last post by  peimaritimesledder
#1 ·
I have to bleed my oil pump, I read a procedure of holding the reverse button an thumb throttle, worse case I'll unhook it an use a power probe to run the pump my question is do I just pump oil into the motor during this bleed or unhook the lines? Any suggestions are appreciated
#2 ·
You need two power up harnesses. One for the SCM power connector and one for the DC Power connector.
Once both are plugged to a fully charged battery, hold the brake, reverse button and throttle and the pump will start pumping oil into the engine.
I did it three times to get the air out of the lines.
#10 ·
Are the power up harnesses available to purchase or can they be made easy enough? I will have to bleed my pump...
#7 ·
That’s what I did. Each time I turned the motor over by hand slowly using the clutch. My entire engine was out and rebuilt. I had quite a bit of air in the line.
After the pump started clicking/pumping I let go of the controls and shined a flashlight down there and could see the bubbles being pushed out.
It did smoke a lot...I’ve got 50:1 premix too.
#17 ·
The 800 uses a single base gasket which should be installed bead up. No sealant recommended.
  • Like
Reactions: Sledtuner360
