1 - 20 of 50 Posts
I saw Bikeman has REV style power valves for the F7. Has anyone tried them and did you see performance or HP gains?
:banana:
Banned
you will see 0 peak hp gains with proper adjustment, you may gain in the midrange though
Krom
Banned
are these the ones mark is making at supreme tool ?????
Banned
Originally posted by cjt@Sep 17 2005, 10:09 PM
yes they are
<div align="right">index.php?act=findpost&pid=879618
kind of figured so :div20: thanks, they remove a lot of questions as far as actual workability goes,ie,,,,non working servos, cables jumping off pulleys, etc, etc,,,,,,,one less thing to worry about,, :banana:
the rev vavles dont have the cords right?? or whats the difference
Originally posted by dead1dave@Sep 18 2005, 06:59 AM
If these type of valves worked better ..........I bet they would have came with the sled .  :dunno:
<div align="right">index.php?act=findpost&pid=879900
And ski-doo is using electronically controlled valves on there power-tek motors! :dunno: :dunno: :dunno:
Originally posted by cjt@Sep 18 2005, 02:54 PM
not from the factory!!!
<div align="right">index.php?act=findpost&pid=880468
I think it does even from the factory . I realize it doesn't mph very well because of the belt , sec. issue but the corner to corner general all around ride is pretty good . :dunno:
Why would you want to disconnect your valves and run the ski-doo style ? What advantage is that ? :dunno:
from what has been explained to me you they gradually open not the "POP" you get with the servo motor,so they can start opening a little sooner and make the exhaust port larger,more power earlier. if you look at the dyno sheets you get a huge increase in hp&torque at the moment the valves open so if you could open them just a little bit,and abit earlier,my guess is you would have a more linear power curve! (forgive spelling)
From what I understand both the 05 and 06 ECU open instantly upon throttling so no"pop" theory for them. I think what it does do is eliminate the worry about cables, length, tightening etc., but does little more than that. I may be wrong though.
ptm
I thought that I might get some for my D&D 1010 so I could dial in more bottom end torque on the dyno. They were a lot of money and did not seem needed. Although if doing a motor swap they would help or on a mountain sled maybe.
They do get rid of a lot of wearing parts and maintenance.
If they weren't so expensive more people might use them.
<div align="right">index.php?act=findpost&pid=880732
im in the same boat on that one maybe if they were around $150-250 more people might get them. i know i would but for $450 i will kep mine how they are
Had a set on my 1000 Twin and they seemed to work good. Power was really smooth and they're easy to adjust. Only downfall is the $$
Banned
<div align="right">index.php?act=findpost&pid=880849
FWIW,,, if you only knew how many folks have had servo problems that cost $$ out the a$$, the price wouldn't matter, believe me :Wow1:
1 - 20 of 50 Posts
