From a member reading and learning from this forum what was the reason the rip saw 1inch track slows a sled down in a drag like that? Is that a heavier track or not as efficient track, which track would be a better option?
[/QUOTE]
Good question, the rip1 track in general is a great all round track , good top end , lugs are fairly stiff , good hook up. However at a 151 length the rear suspension didn’t transfer like it used to. To much leverage behind the rear arm mount at the rails , sled would not 60 that good 1.65-1.80 on dragy. This track was narrowed to 14 wide which took about 3.5 lbs off. Stared life at 49 and change, so roughly 46 lbs.
The track I usually run is a 144 hacksaw ,it’s 39 and change. The other significant change was gearing, was to low, only geared for 107 needed to be geared up some..
