Best value/durable battery
5.8K views 25 replies 24 participants last post by  Jnitty93
#1 ·
I did some searching on HCS and didn't find anything on a "must have" battery and if there's something better than the Polaris OEM one. I'm reaching out to find out if anyone has a strong recommendation for a replacement battery. It seems that Lithium isn't really a good option? I've heard they don't work well when it's really cold and the price doesn't fall in the "value" category. I'm open for a battery that will last, has good starting in the below zero weather and less expensive than the OEM. TIA
#4 ·
I get replacement batteries from Batteries Plus. They put a 2 year full replacement warranty on their batteries. Batteries often fail before the 2 year warranty period and I get a free replacement. This seems to happen whether I buy the name brand or off brand batteries. I do keep a maintainer on the batteries in the off season.
#11 ·
Maintainers pay for themselves very quick.
Have a Sportsman that used to eat a good Interstate AGM battery at least once a year plowing snow, farming, pulling dead vehicles around until I started putting on a maintainer. Battery now on third year.
Our 16 ProX has been on maintainer since new with orig owner and now us. Battery will be used again this season.
I started using maintainers on my cars that go into storage every winter and haven't changed a battery yet.
Maintainers are worth it
#15 ·
Factory Polaris battery is a Yuasa. Simply go online or your local dealer and get the exact battery model number listed on it. I did last year and saved $50 because it didn't say Polaris on it. One year warranty with Yuasa. Years ago I bought a MotoBatt and it had a 2 year warranty for the same price, but the factory Poo battery hold down did not work the same so I had to modify it.
#18 ·
Have a Noco Lithium in my Assault since new. It has only been on the charger once. It seems to go into a sleep mode when not used frequently because it never goes below 12.1 volts. They do state that it's usable to -20C, and they are correct about that, two times my sled had been out overnight and temps got to -25C and the battery would not turn the engine over. Surprisingly the 850 are easy enough to pull start, and within 3 pulls sled was running. After that initial manual start up first thing in the morning, the battery started the sled the rest of the day.
#19 ·
I have pulled a lot of Polaris Batteriers to replace and they say Polaris YUASA which are very good batteries. I have been saving money and replacing with Firepower batteries which also have been working great for use. I have a 12V Firepower Feather lite Lithum in my sled which is only about 3-4" and featherlight. I don't have E start but use it with my power up kit to keep my PIDD runing after I shut my sled off. Works great and have been using for years.
#25 ·
ive tried lith batts couple times. always go back to the stock one. reliable and never let me down once. when its freezing outside it just starts. liths work like crap in the freezing cold in morning. last thing i want to do is pull a rope with frozen stiff engine.
