god damn it, im doing last minute things to my sled for races, im 10 minutes late already, got the flap re chanied, visor hooked up ( again and again )
BUT i go to change my belt....... its my first cat, on yammie you push in and turn, pop off belt
WTF U DO ON CATSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSs
either im having a bad day in a rush or what but is there a trick, reply asap
thxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx
Same thing, put brake on. turn inside sheeve and press on the roller.
only thing with these is the springs are so tight also little to no movement.
On my F5 I have to partially get it off then pry like hell. To put it on I get it
started then I spin the clutch (or track) to get the belt all the way on.
We are the same as you, "Blue at heart." The first thing we did was take the brace off behind the secondary and threw it in the drawer. Then the way we take off the belt it is take ahold and pull UP ready hard, and peel it off the side. Then you have to work it between the side panel and the primary to get it out. To get a new one on, we put it on the primary, then get it started on the secondary. There isn't enough room to do it like with the Yamaha's, but try, and you will be able to push the belt down in a little, then rotate the secondary backwards until it is on. Thats the only thing have have been able to get to work.
Good Luck.
P.S. Where are you racing?
