1 - 8 of 8 Posts
my friend has a 07 dragon, around 80 or 90 mph the belt slips bad. it did this brand new when it was stock and now has a slp pipe, silencer and 66 gram weights and a blk/red spring i think. also belt deflection is properly adj. are the 175 dollar belts junk can u run 3211080 belt for a pro x they seem softer, or what is the deal. any help would be great..
How do you know that the belt is slipping? Yes, you can run the 080 belt, but it will drop your rpm some.
never had a slipage problem with 2300 miles on orig. belt. (I do run the belt a little tight).... I did notice that the 080 belt (new spare I had) started to delaminate from the heat. I have a new 3211115 and will be putting some venting on the belly pan for heat removal. and yes the $170 for the belt BLOWS!
Banned
never had a slipage problem with 2300 miles on orig. belt. (I do run the belt a little tight).... I did notice that the 080 belt (new spare I had) started to delaminate from the heat. I have a new 3211115 and will be putting some venting on the belly pan for heat removal. and yes the $170 for the belt BLOWS![/b]
Yes the price blows, however the longevity is second to none.
Try a Ultimax XS that retails for $99.95 with a one year warranty. My 2005 900 ate 3211080's in near stock form and the XS's are now lasting well over 1000 miles.
1 - 8 of 8 Posts
