1 - 18 of 18 Posts
When I put my Dakota clutch in, the belt was not as high as this picture. I have put about 300 miles since instal. Is this to high. Should I put the thin washer back in? When on a stand, the track rotates kinda' fast; if I put my boot on the side of the track it slows an requires a bit of presure to stop. TIA
Put just a little more in, until to doesnt coast on the track stand.
You are basically starting in the lowest gear possible, which IMO, is the name of the game. Higher the better in my book.
Pat
thats not belt deflection it is how loose the belt is, your owners manual will tell you how to check belt deflection
My belt seems to be riding in the clutch pretty good after taking one small shim out, but the belt has alot of pla when I push down on it. Should I take more shims out or no?
just by looking at the picture, you should be half way between where you are now and the "low" part of the belt. Maybe OK??
That picture IS belt deflec. just a differant way to measure it. I have never used the straight edge, measure down. Too many variable.
belt deflection should be between 1 1/8" - 1 1/4"look on page 6 of the pre delivary instructions it will explain every thing
Administrator
Another thing to keep in mind ... the comment was made about your track rotating while on a stand. That is NOT a bad thing. You just want to make sure that when the sled is lowered off the stand it doesn't "creep" on you. I would suggest the thin spacer as well.
Chris
I agree with LabonteF7, it's good for your track to spin on the stand as long as it does not creep or squeal when on the ground. This will provide you with the best hole shot.
How is that belt deflection? From what I understand belt deflection is how parallel the clutches are. I don't understand how, how high the belt is riding in the driven clutch can measure this.
Mine is sticking out about 1/8 inch-i had 4 shims in there,i pulled a .060 out.Anyways my belt deflection is
1 1/8"-measure your belt deflection,not how high its riding the secondary.If your sled doesnt creep on snow you should be in the ballpark.
I'd say that's riding a little too high and you'll probably hear it squeel sitting on the ground.
1 - 18 of 18 Posts
