Anyone know if there is a base drain on the 550 fan ('03 Trail Touring)? My buddy had problems with the cylinders filling with gas when stored for any period of time, and I want to make sure as much gas as possible has been removed before we take it for a test ride.
Yes below the exhaust y pipe ,down near the bottom of the base,one plug per cylinder,you need a 10mm or a 3/8 socket to remove them,repair the carbs the floats are sticking.
Good luck!
Thanx for the info. We'll be working on the carbs tomorrow night (then probably mowing the lawn - it's supposed to be near 60 tomorrow).
