Taking apart my suspension on a 2015 Arctic Cat xf9000. The axel that holds the front arm has a bolt on each side. I have one bolt out, but I can’t unlock the other bolt as it just spins.
I’ve tried the usuals. Added a spacer/washer (actually a wrench) on the loosened Bolt and then tightened it back up, and then try and loosen the other side. Still doesn’t work. Bolt with spacer just spins. Using impact and wrenches. Nothing works.
Tried applying a little heat to bolt. That didn’t work. Still spins.
Any ideas?
Any ideas?
