O.K. guys, I bought a used 98 xc7 parts sled and i am going to use the bottom in my 98 6. My question is if i remove the crank out of the 7 case can i install it in the 6 case? Why you ask? A crank bearing went, so i splitt my 6 case and been cleaning up the castings (blueprinting) and im hoping the 6 case will be less distorted if any. Also im replacing the seals and want to make sure the crank bearings are clean and well lubed for start up. I know i should send out the crank and have it rebuilt and matched to the case but snow is right around the corner :linemup: What do you think? Sorry about the long post, but we know how important our sleds are. Thanks, all the best, Sideways
The bottom ends are the same on those two motors.[/b]
Yup, just wondering if their is any reason not to swich homes for the crank, probably overthinking, GET ER DONE! :frech32:
