On my past zr500s-01-02 apvs they ran a vent hose(for cleaning cycle)from the exhaust valves down to the ground-anyways on my f5 i noticed oily residue on the oil reservoir,right under servo motor.At first i thought my oil reservoir was cracked,but upon cleaning up i noticed the oil was coming out the cables by the servo motor.Thats means the exhaust-oily residue-from self clean mode is following the cables right from the valve all the way up to servo motor.This cant be a good thing!!!Will gum up the cables dont you think????Why didnt cat run a vent hose?????????Confusion has set in again-scott
My F5 is the same way. And after a couple hundred miles you can see it. What will be like on a good mileage year, the Exxon Valdez ?
