twice the cable has come off the servo motor, whats the fix here.
I cleaned the valves at start of season, but that was 2k miles ago
2014 XF800 137
If you are using alot of oil (high alt. riding) you probably need to clean your valves again.
Rotate the servo motor clockwise and let go, clean valves will pull servo counterclockwise with no help.
I agree with fast 600, if the valves don't turn the servo drum, the valves/cables need cleaned. After cleaning, try a dab of silicon on the end of each cable where it fits onto the drum. That way, even if the valves stick a little, the cable will not come undone. Some valves have more of a tendency to stick when they're cold (possibly due to the brand of oil used or how much oil has accumulated on the valve and in the cables).
