I was looking more for how many times out the air fuel screw was supposed to be turned. I thought it was like 2 1/2 but i have no idea.
I got the track but it hits the front cooler just barely so i bought some 8 tooth drivers and i think they are coming today. :banana: I will get some pics of it when its mounted.
<div align="right">index.php?act=findpost&pid=934993
On the round slides its called just air screw. At 2 1/2 turns you would take most of the tension off the spring and run the risk of backing it out from vibration. 1 to 1 1/2 out would be a better setting. Make sure the pilot jet (up the tube in the float bowl) is clean it will effect the setting. Dirty usually means more turns out
