1 - 8 of 8 Posts
Guys,
I know there has been alot of discussion on the problem with this sled missing, having a dead spot, etc. I am down to checking the Stator. I tried to buy a manual for this sled on Ebay, and the dude had it advertised wrong, he sent it, wasnt right, sent it back, BLAH BLAH BLAH... anyway, I am wondering if anyone could post the proper checking methods on here.
Thanks !!
no info to offer,but i'm gonna tag along here to see what you find out.
having some of the same symptons too.
high rpm bog/miss. sounds like it's breaking ip under a hard load,then sorta coughs it up,and screams again?
is this like what you are getting?
have you checked the TSS?
you need to check resistance, and peak voltage. I have the cat manual at home i can get the specs for you when i get home from vacation if someone already hasnt replied by then.
have you checked the TSS?[/b]
Rip..... this is exactly how mine is acting. Yes i did check the TSS... i found a broken spring in my primary clutch, and thought it was just binding up the clutch and sucking the life out of the engine. After changing out the spring, i ended up going completely back to stock setup and took it back out.... acted much much better for a little while... thougt it was almost fixed... so i went ahead and ripped the clutch completely apart and rebuilt it. I put everything back together and it ran great for about an hour. The same symptoms came back so i said screw it, and went ahead and bought a new clutch thinking that maybe my rebuild had a problem. After getting the new clutch on the sled i found it ultimately did the same thing again after about an hour.... talk about frustrating. I was in canada at the time and the guys in that area dont know much about Arctic Cat's so my trip came to a quick end. What is incredibly wierd, is that when it "breaks loose" and wants to run right, it seems scary powerful... like it is running wayyyyy lean... I thought for sure i was going to burn it up before getting back to the lodge where we were staying.
Steve... I am still trying to get ahold of a manal for this thing so if you can get info for me i would greatly appreciate it...
Thanks to all
Thanks to all[/b]
Here ya are:
Capacitor Charge Coil:(3 wire harness from stator, black,green, and brown)
between blk-green. Read 36.8-55.2ohms
Injection Coil and Energizer Coil:(two prong connector from stator to ECU, blue, white)
16.8-25.2 ohms
Fuel Pump Energizer Coil: (two orange wires off stator harness)
1.4 - 2.1 ohms
Lighting Coil: (4 prong connector, two yellow wires)
.07 - .10 ohms
There ya go for resistance bud, that you can check with any basic multimeter, if you have a high tech multimeter that can read Peak Voltage... ill post the peak voltage readings also for that sled. I only know 2 people that have these meters, and its be cause they work on sleds for a living. (its a Fluke Model 73 Multimeter)
ohh and sorry i took so long to post, been busy with work.
1 - 8 of 8 Posts
