1 - 2 of 2 Posts
I have a friend who has a 98 Bravo 250 Ext. Track and it seems to be running lean. He is using the right fuel mixture and wants to know if the carb has a needle he can adjust to richen it up a bit. If so where on the carb is the needle located. Thanks.
If it’s running lean, good chance it needs the carb cleaned. The jets are probably partly blocked. Heres a link telling you how to clean Mikuni carbs.
CLICK HERE
1 - 2 of 2 Posts
