1 - 2 of 2 Posts
hey guys,
We here this alot but here it goes..
5000 miles on engine.. no rebulid done to it as of yet...
what do i do? rings , jugs , pistons . I know it needs a drive sproket bearing, what esle should i do.. water pump etc...
Also , what is the proper off set for the clutches
and last but not least...can I buy just the reeds or do i have to get the whole thing..
thanks
ps... I HATE JANUARY THAWS grrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrr
ant
If the jugs are good just pistons and rings and maybee a pin bearing. You can have a nice engine by shimming up the cylinders and cut the heads the same. Check with a Cat performace shop for the shim kit. Cheap easy 10 hp gain. If you have to have reeds you can just buy the pedals
1 - 2 of 2 Posts
