I have a 96 Ultra which I recently put SLP pipes on.
I am having a little problem tuning it.
Sled runs great and pulls hard from 5500 on but has a hesitation or bog off idle untill that point.
2200 feet elevation
dropped my pilots to 30 as SLP suggests.
I am running the SLP needles dropped all the way down as I was getting some loading up when I had the needles at the second or more position. Concerns me a little to have the needles on the leanest setting for my altitude, but as of now that is all I can do to clean up the midrange.
I have taken the carbs apart and sync'd them.
Seems it either idles at 1200rpm or with a slight adjustment it wants to idle at 3000rpm. So I'll take the 1200rpm.
Compression is good in all 3 cylinders.
I purchased some 35 pilots, but was unsure if I should throw them in.
Any suggestions to get rid of my off idle bog would be much appreciated.
thanx in advance.
2200 feet elevation
thanx in advance.
