'92 v-max 4.........headlight only works on high beam. Bulb and switch are new but I found the wiring harness melted from the pipe. I fixed the melted wires but still no low beam. I followed the wires from the switch to the light and they look fine. Any fuses anywhere? Any ideas? Thanks
I think I'd try another bulb, before i got too involved.. If that doesn't work, look at the wires to the dimmer switch, there will probably be 3. one is the power coming to the dimmer switch, the other two send voltage out to either the high beam filiment or the low beam... with the engine running the 1 wire should always have voltage, just test the other two wires & see if you have voltage coming out of the dimmer switch..
ok...thanks!
