i tried to set the needle jets on the bottom of the slide and forgot whare the clip goes on the needle. the problem was the oil pump adjusted wrong so i tried to put more gas in it and now 1 cylinder is not dooing good firing Does any one know what slot i put the clip on and the oil pump setting on this beast???
need clip goes on the 3rd .....going from top to bottom.........as for oil pump........set your carbs first and then line the marks up at the oil pump.make sure they are in a line.......or you will have too much oil or not enuff and booom.
someone told me 3 down on one and 2 down on another??? i set them once bot i forgot. im gona try that thanks!!! i just noticed i have oil seeping out of the rave valve on the PTO side, maby i put the clip 2 down on that side?? il take a look and let you know...
