1 - 12 of 12 Posts
Would anyone know the angle of helix in my EPI clutch kit for my 05 900 fusion just wonder if it is 719 or not EPI wounld'nt say what it was. kit came with helix????????......76-10 weights........1 red...1 yellow primary spring's......1 orange secondary spring. One other thing this kit is for a 06 900 fusion and 900 switchback if it matters at all its what the shop here told me to get.
thanks mike
it's not the 719 helix... i think the epi helix has shallow angles but i'm not sure what the number is...
I have that EPI kit in my 05 900 ,Yellow Pri and Orange Sec. I also called EPI because I did not need 2 -719 Helixes They would not tell me the angles (big secret) but they did tell me it was not the same as the 719, just changing it to the 719 works really good for me, with the rest of the EPI kit.
i thinki may have the angle i was on team and the only thing close to the numbers thay had and the numbers i have left on my helix are 420478 42ER Straight 44ER Straight would any body be able say im on the right track??????
[/b]
X2 I have the same set up and it pulls like mad.
All I did was change the helix and secondary spring and it's a world of differance, It just keeps pulling.
All I did was change the helix and secondary spring and it's a world of differance, It just keeps pulling.[/b]
how does it pull out of the hole?I want to do something to my 05 900 but not tosure what to do? What helix did u use and what colour of springs are u using
aren't you over revving with that set-up? glad to hear she's running good for you.
What angle do you have the helix on? Assuming you have the 719. And what other mods do you have?
Discussion Starter · #12 ·
its stock right know have torque arm and push arm clutch kit have a slp pipe and can will put on after warranty and have air box on order...
1 - 12 of 12 Posts
