1 - 20 of 552 Posts
Just picked up a 2019 Indy 850 with 700 miles. Owner is running Amsoil Interceptor oil. What oil is everyone running in the new 850 motor? Thanks!! Art:thumbsup:
Ves orange top or ves extreme white top. Not debating oil quality but electric pumps are metered for a known consistency of a manufacturers oil. (How thick it is at certain temps is the variable )
20 850 Assault
So you're telling me the electronic oil pump is designed to run only Polaris oil because it is a specific viscosity? I find that hard to believe.
Sort of. I’msayi g they have the metering of the oil pump set to provide X amount of oil at positions and that X amount of oil delivered was derived by using thier oil . A change in the oil could /will change the mount of metered oil. In fact I believe if you run extreme (thin) and the ves you will see an increase in consumption with the extreme.
Your manual says VES until -35*F and colder use the Extreme. The Extreme can be used at any temp.
That said,I don't have the new 850 but I am a heavy Mystik oil user. Passes very high oil test standards.And it's pretty cheap ! :)
<------ Pretty good testament right there (you've heard of the famous 05 900 right ? LOL) with original pistons,although pretty sure I'll change them for next year. :)
20 850 Assault
In a sealed injection pump, the viscosity of the oil should not effect how much volume is injected .
Exactly, if it's a positive displacement pump it moves same volume every time regardless of viscosity.
Correct. :thumbsup:
Oils are tested in centistokes (viscosity) at two different temps- O*C and 100*C, which have little to do with snowmobiles,so hard to compare + the OEM snowmobile oils, as we know, typically tell us nothing,noteven what standards they pass. :wall:
Okay. maybe I shouldn't have assumed what type of pump/system it uses. I will look into the electric oil pump system used more thoroughly for my own knowledge bank. :thumbsup: Feed/supply can still be effected...I'll see.:)
If this is so then why is more oil delivered with thinner oil and less with thicker ? At least it appears to work that way. I have t exactly measured it.and with that being said why do they make oil for low pour points if it flows the same. So maybe flows out of pump the same but not into pump the same? I Will Have to wait till nxt year now to actually test the results. I’m no pump expert so there could totally be something I’m missing here but I’m pretty sure it would vary.
Well boys mine has had everything under the sun in it when i’m running up north hard and the oil I packed hasbeen used up I feed it what I can get 3500 miles 8/23 engine build date
On another 1000 mile trip starting tomorrow
20 850 Assault
I would like to know more about the oil pump myself. It is most likely a positive displacement pump, just not sure which. Possibly a solenoid operated piston pump, or a small gear mesh style, not sure. I like the idea of the ECU controlling it, not strictly the throttle lever. I do have my concerns with electronic gizmos however.
1 - 20 of 552 Posts
