1 - 20 of 37 Posts
Super Advanced Lummox
I have been too busy making the sled good aka custom decals,skidplate,new windshield etc
I should be paying attention to the parts that really need to be changed
Well I knew I had to change the carb flanges as they are cracked
But I never ever thought of looking at the carb boot between the carb and air box
:Wow1: It is in bad shape and to top it off it cost :augen41: $80 to replace
Where the hell does Cat get their rubber made :dunno: china????
and for the carb flanges $50 I am going Kimpex $20 aka can't be worse then Cats rubber
the sled is a 2001 the rubber should be almost new :banghead: ,the rubber on all my Indys,Doos and Yamahas never cracked like this
I knew it was a problem on late 90s Cats but still never thought a 5 yr old sled rubber would be so deteriated(sp?) :smashpc: :frech32:
I don't want to spend $80 for a carb boot,when I could find a whole airbox for less
Sorry just a little peeved to spend nearly $200 on rubber parts for the carb area
watch out for kimpex. everything i tried that they made sucked. have you ever had a throttle cable fly into pieces on the trail at night?
I have been sledding for over 20yrs
And I trust Kimpex quality
I have gotten 3 tracks that where from Kimpex and they lasted longer then the OEMs tracks
So I am not affraid of there stuff
I still can't beleive less then 5yrs for Cat rubber parts,that is sad IMO
Banned
<div align="right">index.php?act=findpost&pid=884854
wanna' bet?? only if factory boots aren't available would i risk kimpex boots as their boots(kimpex) have less rigid metal and too much(thick/easy to ''smush"/cause poor sealing/air leaks)rubber in critical points, go ahead and get the kimpex boots, better order pistons also, you'll need them,,been there done that over yrs servicing sleds o.e.m. parts not available for, seen air boot surface ''smoosh/warping'' too many times for me to feel safe with them IMO,,,,,,,
Discussion Starter · #7 ·
<div align="right">index.php?act=findpost&pid=884873
I am getting kimpex carb flanges aka between carb and reeds
The carb boot I am getting Cat parts aka between carb and airbox as I am sure its a dealer only part
just trying to clarify :div20:
Banned
<div align="right">index.php?act=findpost&pid=884879
^^^^^^^^^^^^^^^^^^^^^ i knew what you meant before last post,, the ones above(between carbs and reeds) are the ones i meant as being risky, just clarifying for you,,,,, :cn:
They make carb boots after market. I bought one carb boot from spi on my old triple and two polaris boots. the spi boot actually melted for no apperent reason. It got mushy and formed a hole in less than two weeks. the polaris boots were fine and so was the one I ended up replacing the spi with. The worse part was they would not stand behind there product that was only two weeks old. P.S. the only reason I bought the spi was because they only had two polaris brand in stack at the time.
You may want to check into that kimpex boot further. I looked at them a couple of years ago and the aftermarket boot didn't have the stuffers for the stock reed cages...
This goes back to the storing the sled outside. I really believe this. I picked up my '99 last year, same thing, Airbox boot rotting. Bought it from a friend of mine and it stayed outside plenty. Yeah my boot was $50. :banghead:
Alot of people like to spray everything under the hood with WD40, this is not good for the Rubber parts, drys them out and they rot.
Go salvage or e-bay, there are many of these model sleds being parted out every day.
<div align="right">index.php?act=findpost&pid=885277
That is correct, WD40 is a no-no!!! :doh:
Discussion Starter · #15 ·
<div align="right">index.php?act=findpost&pid=885271
The guy I bought the sled from stored it in his pole barn :cn:
+ I have always stored my sleds outside covered of course
IMO this is just poor quality parts that Cat uses :frech32:
Been sledding for over 20yrs and never had this happen to any of my Yamahas/Polaris or Doos
Oh ya what a pain in the ass to remove the airbox :frech32:
BTW I am guessing here but an airbox from a ZR800 or 900 carb would be the same as the ZR600 carb also had 40mm flatslides :dunno:
I had to replace my boots 2 years ago. Every person I talked to about it said stay away from aftermark places when buying boots. Granted my boots were shaved and this is why mine ripped and yes I found out the hard way at about 95. I usually don't reply to posts like this, but the only reason I am is because I talked to about 12 - 15 people and they all said the same thing about sticking with OEM for boots. Just my 2cents
QUOTE
Hence the accelerated drying and cracking.
IMO this is just poor quality parts that Cat uses :frech32:[/b]
They come from Mikuni, same as the other sled makers.
Been sledding for over 20yrs and never had this happen to any of my Yamahas/Polaris or Doos[/b]
I have, loosen the clamp and any Mikuni flange on a Poo/skud and you'll find cracking, been there/done that.
Oh ya what a pain in the ass to remove the airbox :frech32:[/b]
Granted it could be easier but still should only take 10 minutes after doing it one time.
<div align="right">index.php?act=findpost&pid=885493
[/b][/quote]
I wish you luck, as was mentioned earlier if you insist on using Kimpex consider ordering up some pistons and have a box labelled and ready to go to Millenium.
I had to replace mine on my 99 cat this summer when i picked it up, That and many other little parts....i guess i should have had a closer look,next machine i buy will be gone over alot better.
1 - 20 of 37 Posts
