Can't figure this out. After sled sits for a few days it will not start until I change spark plugs. Can pull and pull and will not start on the plugs that have been in sled. Can change plugs and will start within three pulls. Then shut off put the plugs that were in when it would not start back in and will start right up? I have four plugs I have been interchanging and once started it will run on any plug. I can't figure out why it won't start on the plugs that have been sitting in the sled? Kind of a pain to switch plugs ever time to start???
Couple of ideas. Do you have good spark? Maybe a deeper issue than plugs. Also, make sure you are gettting fuel. Possible old sled had fuel pump issue. If plugs are dry.
Plugs wet, might be a carb float stuck and your siphoning in fuel while it sits.
Good luck.
