2021 650 Launch Edition 137" ; 2014 XF 7000 Cross Country Sno Pro 141"
What temps are you seeing on your 650 under normal riding conditions?
Same. 95-120 seems to be where it runs. 140 a few times on sketchy, snirty conditions.with good loose snow and cold 95
I was in Forest County Wisconsin, most trails were thin, but even some road runs and logging roads got to 135F or so and then stayed. A few trails with fresh snow on them, and it dropped down to 110F.Put 98 miles on today in Oconto County. Temps were in the 20’s. Trails went from 2 miles of pristine conditions then followed by 500 yards of dirt and grass on and off all day. Sled ran at 120-124 most of the day. Saw 133/134 a couple times. This sled runs cool.
I agree. My sled takes a solid 5 minutes to warm up. Usually takes 10 when temps are single digits.I was in Forest County Wisconsin, most trails were thin, but even some road runs and logging roads got to 135F or so and then stayed. A few trails with fresh snow on them, and it dropped down to 110F.
When first started, and idling, this sled is very SLOW to warm up. Once given some throttle it happens quicker. I am running 91 non gasoline, set for the 91 NON fuel type
15 to 20 seconds on a 600. You don't limp very far.It warms up real fast when the water pump gear is stripped out!
