The Accord result was a fluke as they stated in the article.
In the 650, I suspect that neither fuel would show a major difference if used in the ethanol mode. A minor difference could possibly be because the ethanol mode runs richer and the premium fuel if non-ethanol would be even richer. If both are the same % ethanol fuel, then it should be the same power.
One of the most important things about fuel is freshness. This affects full vaporization. Fuel will not burn completely in the combustion chamber if it doesn't vaporize. Premium fuel is often stale due to less usage. This is extremely important in a 2 stroke engine. DTR has seen loss of hp simply due to stale fuel so they test all fuel used for this characteristic using an RVP tester. Fuel that doesn't completely burn actually causes lean mixtures and can seize the engine even though an AFR gauge reading or fuel flow appears safe. Many so called "cold seizures" are actually caused by poor fuel vaporization. Warming the engine up before riding is really helping low volatility fuel to vaporize.
A FITCH fuel catalyst cannister is designed for this problem and is what I recommend be used in all my and my friends/customer's sleds.
Not fair to chalk something up to a fluke if your don't like the results. That is why we test things.
I would bet a statistician would say the results of the Accord, Mustang and Dodge Ram were statistically insignificant. They even kind of say that in the article.
Can you tell the snow is melting? When we are arguing about silly stuff like this!
