1 - 2 of 2 Posts
Vendor
This kit makes your 900 Turbo Ski Doo into a powerful yet very well mannered rocket! We use the Hurricane Performance tune, along with our Turbo back stainless exhaust system, Aluminum charge tubes, and Pro-Shift clutch kit.
The 205 hp tune actually makes 212 hp with our exhaust system. The aluminum charge tubes dissipate heat better for a cooler intake temp. Our Pro-Shift clutch kit harnesses that power in an amazing efficient way. The torsion helix and spring combo allow the clutches to shift out further for more top speed. Our out weight profile of the Pro-Mag weights grab the belt efficiently as well.
The exhaust system is all stainless steel and starts at the turbo, this is why it makes a nice gain in power. The muffler is louder than stock but very trail friendly still. 10 lbs lighter too!
This kit will absolutely destroy a stock machine in acceleration and top speed!! It will beat up on a 850 with a Jaws pipe too. This package is so much fun! It's fast when you want it to be fast and yet it will cruise down the trail nice and smooth and still gets really good fuel economy. You can still turn it down to stock power level by simply changing modes.
Hurricane spent a lot of time making the powerband very well mannered with throttle response, and not like a light switch like other tunes are like. This is a very powerful and reliable kit. You will love it!
TAKE ADVANTAGE OF OUR SPRING SALE!! 15% OFF!!
USE CODE: BDX-SPRING2020
1 - 2 of 2 Posts
