1 - 13 of 13 Posts
Just picked up this sled guy said it has done 117mph on gps but max speed on sled says 96mph? Any thoughts.. has a ripsaw track and two studs all way up the middle. Said has the 2020 flash Is there anything else I should look for or do
Thanks in advance!
If he changed gears and did not have the speedo information changed in the ECU, it could have been that high on the gauge.
I accidentally reset my top speed once on my 800. He may have truth to it. Now my top speed is 105. Was 109. Simple mistake!
The power is so linear on that motor I often found I was going faster than I thought I was.
according to my gauge my top speed was 105.
I reset mine nearly every ride. Either who cares what he said it will do. Get out, try it, and make sure everything is in top shape and it will be as good as it is. If you expect a bone stock, never wrenched on sled to run with a wicked top end you are naive.
20 XCR 850, 21 VR1 650, 21 VR1 850
117 on gps would put max recall into the 120’s. As Phil said there are 840’s obtaining these numbers, well setup 840’s that is. Most everyday riders sleds will never go that fast. But the potential is there.
2020 Indy XCR 800, 2019 Indy 850, 2011 IQ Turbo
I "zero" the recorded data in my guage every ride. If you checked my guage, it might only show 78mph max speed. I'd have never even thought someone might expect that to be maintained as a record.
Thanks in advance!
My old sled....It's done the 117 on GPS on plowed ice. The max speed recall is reset able. Plus when removing hood I think it resets the PIDD. Yes it has the 2020 Flash. I would bring it in for the 2021 Flash. I didn't have any issues with 2019 or 2020 mapping but did find the 2020 map was slightly harder on oil. And VES extreme (all i ever used) isn't cheap.
You are bang on...I think 117 GPS was about 123 on the speedo. Here's only pic I found still on my phone. If I remember right that was about 115 GPS
2019 Polaris XC 850
My '19 XC850 is stock, except for 180 studs has been 114 (speedo) on ice road. No re-lashes ever. Can't wait for winter.....
1 - 13 of 13 Posts
