Before last season the compression on my 2012 rush 600 was 90 psi on both cylinders. I decided to replace the pistons with prox rather than have it blow up on the trail. Had a little over 3000 miles on it. Also turned up the oil pump at that time. 60 miles into the first ride of the year, mag side cylinder lost compression. I tore the motor down, rings were stuck on the exhaust side, looked like it got hot. It was coated in oil so i assumed it to be a vacuum leak or lean condition rather than the lack of oil these engines are known for. There was some oil under the flywheel, so i figured that the crank seal was leaking and that was the cause of the failure, and the only thing keeping it alive before was the lack of power from low compression. I had the mag side connecting rod replaced on the crank because the big end bearing was bad, and the cylinder replated because it was scored. Injectors were cleaned and flow tested and fuel filter was replaced. Reed valves and throttle body boots all looked good. Rode it 130 miles last weekend and lost compression on the mag side again. Im at a loss for what happened. I followed the service manual (correct sealant, torque specs, piston to wall clearance, etc.) I'm at the point where i need to sell it as is and lose thousands of dollars or part it out even though i dont have the free time to do so and try to recoup some of my money. I cant see rebuilding it again and having it blow up on me again shortly after, so unless i can find out exactly what caused it im not wasting more time or money on it. Im just hoping someone here who has more experience than me can provide some insight. Thanks in advance
Sent from my LM-G710VM using Tapatalk
