Discussion Starter #1 (Edited)
What changed in 2011 that the XC model has a different handlebar? If you look it up it as described as 'Handlebar, Heavy Duty - Assembly (inc. [+]
1705-042 & 1705-155'
and is green.
https://www.babbittsonline.com/oemparts/a/arc/54e678d287a8652018ad8c8c/handlebar-assembly
The 500 has different bars 1705-092, curious what the actual difference in the bars might be if any other than color. Riser block is/are the same part # - thicker wall tubing?
The original part # was 0705-978 and fit (but was replaced by the new #'s)
Assemblies where 0705-978 is used
2004 440 SNO PRO (S2004F4BPRUSG) - Handlebar Assembly
2005 AC 440 SNO PRO GREEN (S2005ACBPRUSG) - Handlebar Assembly
2005 AC SNO PRO MOD GREEN (S2005ACAMOUSG) - Handlebar Assembly
2006 AC 440 SNO PRO GREEN (S2006ACBPRUSG) - Handlebar Assembly
2006 AC 440 SNO PRO GREEN MODIFIED RACE SLED (S2006ACDMOUSG) - Handlebar Assembly
2007 AC 600 MODIFIED SNO PRO GREEN (S2007ACDMOUSG) - Handlebar Assembly
2008 AC 600 SNO PRO BLACK (S2008ACDPRUSB) - Handlebar Assembly
2009 600 SNO PRO GREEN (S2009ACDPRUSG) - Handlebar Assembly
2010 600 SNO PRO CROSS COUNTRY GREEN (S2010ACDCCUSG) - Handlebar Assembly
2010 600 SNO PRO GREEN (S2010ACDPRUSG) - Handlebar Assembly
2011 ARCTIC CAT SNO PRO 600 CROSS COUNTRY GREEN (S2011ACDCCUSG) - Handlebar Assembly
2011 ARCTIC CAT SNO PRO 600 GREEN (S2011ACDPRUSG) - Handlebar Assembly
Yes, I am this weird. :)
1705-155 is more than likely just a thicker tube. The 500 and 600 bars were different due to the throttle block being an efi sled and the aluminum throttle block of the carb 600. They likely are the part number of the bar assembly and not the actual bar itself.
Discussion Starter #3 (Edited)
well, here's a 1705-042 bar with just grips
https://www.countrycat.com/arctic-cat-part-1705-042-handlebar-w-hooks-sp-assy-grn
the way they are described in the fiche as heavy duty makes me want to believe they are a thicker wall tubing. highly doubt I'd ever bend or break the stock bars, but I do like the look of the green bars.
google found it
https://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=5&cad=rja&uact=8&ved=2ahUKEwjvmLrXxNXeAhUSbK0KHWPfA_sQFjAEegQIBBAB&url=https://www.arcticchat.com/forum/snopro-chassis-2010-2013/362576-handle-bars-diffrent-variations.html&usg=AOvVaw252tyNBdu9xRWGeCVh-P82
Put a set of fly racebend bars on it. They are thicker than the stock ones and the bend is better than stock. Cheap upgrade
