Just purchased one with 1870 miles on it. Goes into reverse and it works, but flashes the ECU 25 code. I'm new here and I know it's discussed in a few other threads, but more with the later "diamond drives". I haven't seen it discussed with a 2010. Same fix? Most say replace the actuator, and one said to re-seat the fuse and wiring. I saw a video where the mech lubed the actuator with WD40, but that one wasn't working at all. Appreciate any insight you folks might have! -Mark
My 2011 TZ1 Turbo did the same for 15,000 miles, and my 2013 TZ1 Turbo has done it for 13,000 miles. Both had actuator replaced under warranty and code returned shortly after.......If reverse is working don't worry about it....Restart to clear code and ride on!
Agree. I use to see it early morning, on the first shift into reverse of the day, but never popped up after that, way back on my first '09.
