1 - 20 of 28 Posts
There were no F7's produced in 2007.
I know that a 2007 F8 is estimated 503lbs dry, according to specs on Arctic Cat's website; http://www.arcticcat.com/snow/sled.asp?id=745
Good luck on getting a wet weight.
A person could always ball park it by getting the capacity of the oil and coolant reservoirs and the gas tank and adding to the dry weight...?
There was a topic posted regarding weights on the new F series. Try doing a search. I can't recall if there were wet weights included on the topic or not.
NJ
I think it's great that Maximum Sled did this testing but it's hard to believe they didn't screw up some of the info.
They show a Doo GSX 500SS at 2 lbs less then a standard 500SS with no Estart. I have weighed Doo Estarts at 28 lbs alone.
The Estart adds less to an SDI Sled as they already have a small battery.
They show the MachZ without Estart as being 19.5 lbs more then a Blizzard 800 without Estart when Skidoo claims a 50 lb. difference. I can't believe Doo wouldn't be shouting this to the world if it were true. I assume either the Blizzard had Estart or more likely, they screwed up the MachZ testing.
NJ[/b]
Sorry, wet weight for a 05 F7 SP, I will pick up my new F8 SP tomorrow and i just want to know the real weight difference.
They show the MachZ without Estart as being 19.5 lbs more then a Blizzard 800 without Estart when Skidoo claims a 50 lb. difference. I can't believe Doo wouldn't be shouting this to the world if it were true. I assume either the Blizzard had Estart or more likely, they screwed up the MachZ testing.[/b]
Your point about the Blizzard having eStart makes sense since it gained almost 100lbs over dry, where the Mach didn't quite gain 70lbs. Who knows???
I will pick up my new F8 SP tomorrow.[/b]
Congrats!
I'm really liking my F8 so far. Be sure to give it a look over first before you ride though. Some machines have been experiencing some factory hiccups, which you've probably read in the sticky's a the header of this forum.
Nice job Andy...I was just going to sort them after cutting and pasting. ;-)
Look at how the Jag weighs less than the LXR F1000 and a hair more than the F8 LXR...how is that possible???
The thing that limits the usefulness of their comparison is that they wieghed them with a full tank of gas (I believe) and the 'Cats have a larger capacity than the Ski Doos. Maybe a 20 lb. difference???
This is surprising :div20: :div20: Just to let ya know a buddy of mine just scaled his non es mach with 1/4 of fuel at 580 lbs.[/b]
580 lbs makes more sense. Add 8 Gallons of fuel at 6.13 lbs /gal and you get 43 lbs. added to the 580 lbs. or 622 lbs total. This number is far more consistent with previous weight reports on the Mach.
I love my new F1000. It doesn't feel heavy but had I seen this info first, I might not have bought it. I was looking for something that felt lighter then a Mach or RT Gade on the trail. The F1000 seems to fill that need nicely even if it is really heavier.
I love my new F1000. It doesn't feel heavy but had I seen this info first, I might not have bought it. I was looking for something that felt lighter then a Mach or RT Gade on the trail. The F1000 seems to fill that need nicely even if it is really heavier.[/b]
Man I hope so...otherwise Mr. Nasty has a nice little advantage right there...
1 - 20 of 28 Posts
