If I use the 10.4 conversion on my 2005 f7 and a polaris 3211104 belt, how many grams should i go down on the clutch arms? And will the bigger secondary rub on the foot wells? Thanks :help:
Since there is no snow!!!
But from the info I gleaned off here.
You have to go down 3-5 grams.
And apparantly you have to "adjust" the footwell.
Also. You need
1) Deflection adjuster - LH
2) Torque Washer
3) Shave the bushing
I am still waiting the Billet TSS Adjuster from HPE (Man they are SLOW!!!!)
2022 XCR 850 136 still waitng for khaos boost
The way im understanding it that you use all your 05 parts except for the deflection adjuster,that you have to get because the threads are left handed not right haned or vise/versa.or if you run the polaris belt you dont even use the deflection adjuster(thats how its done on the 05 10.0 inch clutch anyway)
<div align="right">index.php?act=findpost&pid=903197
Not even use the belt deflection adjuster? :popcorn:
