1 - 2 of 2 Posts
Just bought a 2004 xc sp when to go for a first trail ride with some buddys , got there and of course it broke, the engine jammed up solid, the pistons will not move.
The clutch will not turn, tried to spin as much as possible but cant get it to budge, front or backwards, could it be a bad crank bearing or the crank itself. Any ideas would be great, its at the shop now want to know what happen no warranty with the sled.
have you tried removing plugs and belt and turn it over that way if you did yes it sounds like seized or hydrolock caused by gas filling the crankcase try removing the lower drain plug (if they still have those any more ) if it drains alot of gas you might be able to restart after it drys out. if by chance you have electric start sometimes the motor jams against the ring gear engaged hope this helps good luck
1 - 2 of 2 Posts
