Can someone who has an 02 ZR800 EFI take alook under the hood and tell me the positioning of the ignition coil that's mounted on the airbox? I had to remove mine and need help positioning it correctly. The following 3 questions will give me the info I need to mount it correctly....
1) Do the spark plug wires come out/point to the clutch side or the mag side?
2) The coil is smoother on 1 side that the other(1 side of the coil looks like the bottom of a boat with white writing on it)..... Which side is mounted toward the airbox, smoother side or side with white writing on it?
3) Which plug wire goes to the cluch side cylinder, the top or bottom wire out the side of the coil?
Thanks much!
-John
Thanks much!
-John
