1 - 11 of 11 Posts
what should the top end on a 2001 ZR600 efi be? I am seeing just below 100mph 120 studs everything else is stock!
ufo-my 01 efi buries the speedo and it is geared down 1 tooth. of course mine is tweeked a little ,but even before it would 100 no problem,did you ck. your exhaust valves ,make sure they are not stuck
2021 VR1 850, 18 Tiger 8000, 17 RS 6000, 16 ZR 6000, 12 F1100T, 11 EXT 800, 09 Z1 Turbo, 05 ZR 900
Originally posted by UFOF7@Mar 23 2003, 07:44 PM
it has 3900 miles on it, so I am thinking maybe it needs a ring job?
Rings are probably fine, as thats not a whole lot of miles on that motor your top speed is about right, what were the conditions like that day? Wet heavy snow?, loose powder?, hard pack? high pressure, low pressure, temps? all these issues affect performance even EFI sleds. So just clean your APV"s if they need it.
I agree, depending on conditions, that may not be that far off. The best that I ever saw on an 01 600 EFI was about 105-106, verified on GPS.
i think my dads went 100 with no studs
My brothers went 110 on GPS bone stock -10c on ice 120 studs down wind :)
no offence but i think thats a tad fast...my 800 outa the box only got 109 no studs on hard packed snow on a radar gun...your bro must weigh abotu 5 pounds...
like aczr600 said, check and make sure your valves aren't stuck, and also
check that the valve cables are in perfect sync !!!! I had to adjust mine every 900 miles
The fastest my stock 01 carb 600 went was 103.
I had 6000 miles and the sled and the compression was still fine.
Pull your valve housing and clean them out and sync those cables!
Just for the sake of argument, my totally stock 2000 ZR 600 EFI without power valves, no studs (except the one on the seat) showed 100mph easily on a long run on a hardpacked lake. Outside temperature was 0 to +5 deg F. These 600's go to 80-85 mph very fast, but take awhile to reach the triple digit mark.
Rings should be fine. My riding buddy has a 2001 600 efi with 7500 miles on and original rings. He gets 100 to 105 on the speedo depending on conditions. Check you're valves, we've had to adjust his several times.
1 - 11 of 11 Posts
