Can someone explain how to check the cable length for my APV cables. How much exposed cable should there be on my 600ZR?
Also, is it possible to check the servo to be sure it is working with out the cables attached?
pop the cover off the servo motor, and slide the cables off. then tug on the end of the cable, while holding onto the metal corner tube. there should be 1 1/4"-1 3/8" of cable showing when you pull it tight.
Your owner's manual should give you this info. I don't know the measurement, but make sure they are both the same, whatever they should be. I use a dial caliper to measure them, and it works good and is very accurate. To check the servo just start the engine and run the engine up to 4 grand or so then let off- they should cycle (for cleaning purposes).
